DarkManX4lf
There is something wrong with my text message inbox. When i receive a text message and reply to it, my message comes up before the one I received even though I sent it after....does anyone else experience this?
...One minor pattern, the two times it has happened the person responded the same minute that I messaged, and it re-arranged them so that the other person's message was first. Don't know if that's the same on your device, but it could just be a time-stamping issue.
I imagine it must be. I haven't had the exact same problem the OP had, but if I am sent a couple messages in a row, they show up in the order they were sent, not the order they were received, which apparently isn't always the same.I have had it happen, too. It's only happened twice so far, so I haven't been able to discern any noticeable pattern in it. It does not happen on the vast majority of texts, though. One minor pattern, the two times it has happened the person responded the same minute that I messaged, and it re-arranged them so that the other person's message was first. Don't know if that's the same on your device, but it could just be a time-stamping issue.
I have this problem with Handcent on my Hero, usually from one particular contact on a non-UK network. I've had similar problems for years on various handsets and SMS programs. It would appear to be down to the time-stamp/zone of the network from where the SMS originates, and is compounded by switches in in daylight saving times etc. I know some handsets are set to take their time from the network; and will show as 1200hrs allowing for BST, but the time-stamp will be GMT.No my location is fine ..I just think there is something wrong with the HTC messenger ....with handcent I have not had any issues with the order of messages
I have exactly the same problem as Dracostian except it is not intermittant. It happens every single time I reply to a text within the same minute.
The other issues people have been reporting in this thread with time stamps showing up wrong are not related to this.
I am running Android 2.3.5 on a Desire HD on the Orange UK network, but i am sure this is an issue with software, not network. It started happening sudenly when it had been fine before.
EDIT: Having read another thread I have reset set the time manually on my phone and corrected as it was out by 1 min, then set it back to use network provided values again. Thinking about it the issue only occured after my phone seemed to lose a load of settigns recently such as the background and the time changed to be completely wrong, but that seemed to have fixed itself after I restarted the phone. I will ahve to wait and see.
