Text messages
TheKingIV
Even when I have my phone on vibrate, when I get a text message, it won't vibrate. The screen pops up to the lock screen and the envelope shows in the top corner, but no vibration.
1) How do I get it to vibrate? (Looked under the message settings and it only appears to have the option for sound)
2) Also, is there a way to get a preview of the message to come up on the lock screen when the message comes?
In Text Settings near the bottom there's Notification Settings. I have Notifications, Select Ringtone, and Vibrate. Vibrate has choices of always, only in silent mode, and never.
Not sure about the text setting. I thought the screen lighting up when I got a text would be problem, but it doesn't show the message so I'm good with it.
Weird...I don't see a "vibrate". This is as far down as mine goes (attached).
They need to add an option to make it so the screen doesn't turn on every time I get a message
Very true. What's the point of it anyway if it doesn't even show the message... So you can see you got a message from across the room? The big blue LED should be good enough!
