text messages
I cannot receive any text messages on my samsung galaxy precedent phone. I got a message saying memory was full, but I removed all the text.:confused:
Welcome aboard. :)
You should clear cache from all applications on the device, as well as follow the steps below.
Go into Settings ---> Applications ---> Manage Applications and wait for this list to be populated with not just the applications but the amount of memory they are using up. Select a larger app and on the next screen if the the app can be moved to the SD card you'll be able to push the Move to SD button. Repeat the process for each app.
Also check inside your device's support forum for tips & tricks and info on this phone. Link: Samsung Galaxy Precedent - Android Forums
Cheers!
