Text Notification LED
Donjo
Member
I am currently using handcent and while I did tons of searching I can't find the answer. My notifications are set for a blue led through handcent which is my default messaging app. The light at the top of the screen does not illuminate what so ever for incoming messages. Is there something I'm missing??
There is a free app on the App Store called Light Flow lite that lets you fix this. It allows you to customize all of the notification light for the apps on your phone. If you pay for the full version it unlocks pretty much every app. It works really well. Give it a try.
i used to use the app light manager when i had handcent. it works well and you can set it per person. I haven't had much experience with light flow, so i can't give my .02 on that.
