Help Texting Error???
DrChris
Hi,
The last few text messages I've sent have had a little envelop with a green " i " in a circle beside it.
The message is sent ok.
I just don't know what it means :confused:
Sorry if I've over looked a thread that may have helped, or if I've posted in the wrong section.
It's basically showing you if the message was sent successfully or if it failed, if you long press on the white envelope you can check the delivery status too!
Just make sure you have Delivery reports enabled in the settings :)
