Texting Issues, Txt+ vs GOsms
Text Plus works fine, but i really want to try GO SMS. So I downloaded it, and it wont send any messages. Do I have to uninstall TextPlus? Is it blocking GOSMS?
Also is there a function that will allow a text to pop up over the lock screen?
Finally, how do I uninstall the stock SMS program?
Try uninstalling Txt+ and using GoSMS. See if GoSMS will work then.
GoSMS has an option to unlock the screen and turn it on when you receive a text.
To uninstall the stock SMS program, you'll have to root your device.
So here's where I'm at.
I found that the latest GoSms update has a lot of users peeved and having issues like messages not sending, trojan alerts, etc.
I uninstalled TextPlus to see if GOSms would work, it didn't. I re-installed GoSms, still no good. Finally I uninstalled it and reinstalled TextPlus until GO gets their shiv right.
Now I have an issue on TextPlus where I sent a photo to a friend but I'm not recieving the photos that others send to me.
can anyone help?
