A Android Question Guest Feb 19, 2016 #1 Is there a way to get word suggestions while texting for my S6
girolez Often Off Piste Feb 19, 2016 #2 Hi Have you enabled Predictive text in the keyboard you are using? Probably system settings language and input samsung keyboard (or other if you have a custom one installed) predictive text - set to on
Hadron Spacecorp test pilot VIP Member Feb 19, 2016 #3 Predictive text? The real question is surely why you don't have it - that sounds abnormal. Check your keyboard settings in case you've turned it off.
