I read that Voice has a long lag/delay, unless you set it for very frequent updates, which will drain battery. Can anyone shed light on this? Thanks!
There is no Compose in my menu. ?? I see:
Refresh Labels Balance
Search Settings Help
Nope -- that's unrelated.I don't understand. Maybe it is because I opted out of letting it be my voicemail app??
Unless you're a non-corporate Sprint user and opt for integration. Or port your number.Keep in mind that for any text you send using Google Voice, the recipient will see your Google Voice number as the sender - recipients may not recognize the messages as being from you.
