Help TF101 will only power on if I have it connected to external power
Dorrin
Hello,
I have a TF101 that will only power on if I have it connected to external power and the battery does not charge. The battery shows as being at 27%. If I try to power it on without having it connected to a power outlet nothing happens. If I plug it in and power it on it turns on but does not show the battery as charging. While it's plugged in it works without issues but if I unplug it the tablet powers off. I have already tried returning it to factory default settings with no luck. I have also tried upgrading it to the latest firmware with no luck. I also have a TF300 and have tried charging it with that power connector but with the same results. Out of despiration I replaced the battery. Before battery replacement it behaved the same but was unable to detect what the battery level was at, making believe it was a battery issue. With the new battery it started at 25% and powered on normally. I then plugged it in to charge and after 5 minutes the charge symbol on the battery icon went away, it was at 31%. From there on I could still turn it on without the external power connected until it got down to 27% and now the issue is back.
I have only tried charging it via wall outlet as I do not have USB 3 on my computer to charge from.
Does anyone have any ideas on how to fix this?
Thank you
Are you sure the wall wart is good?
The tf101 will charge at a trickle via USB with the screen off. Give that a try.
Just an FYI you do not need USB3, USB 2 will work but as stated above it will be very slow, the TF must be turned off and the will show no indication that it is charging other then waiting for at least 4 hours and seeing the battery charge increase.
