existinguser
For everyone who have messed up their roms, there is a totally nice sulution tu unbrick the asus eee pad transformer!!!
I done it and it works!
What you need:
download this file http://www.filefactory.com/file/ccda97c/n/nvflash.zip and this one http://www.sdx-downloads.com/devs/roach2010/flash_roms/prime_v1.4.tar.bz2
Then extract the first file into its folder, then extract second file into first files folder (there are 3 files in second file)
Then turn off your transformer,
plug in usb to pc.
turn it on in APX mode (volume up and Power at same time)
There will be no notification on transformer.
It will remain in black screen.
Then find the APX device in Device manager and update the driver by pointing at the usbpcdriver directory in the Nvflash folder (the folder you extracted first files to).
go to windows and enter cmd. Type in full path of the file download.bat in cmd window and press enter. Then let your transformer be alone for like 20 minutes, and voila! Rooted, unbricked, working
Oh, and battery should be at least full for security reasons.
And dont download other Nvflash versions online, cuz only this one works.
If you cant get it for free from the homepage, email me, i will email it for you.
I just chipped out 12 dollar baby, but **** it. It was worth it. Oh, and **** asus warranty lol, those asses wanted me to pay crazy money to repair this.
Hi, i have a 3.2.1 rooted Transformer tf101g, and the longly waited OTA of ICS has finally arrived im my region. kernel version 2.6.36.6 android@mars #1
But the funny, or actually a sad thing is - that when it downloads the new update, when it restarts, and starts installing it (after the firmware integrity check, which is fine), one third of the way it comes up with an exclamation bar and halts. Then if restarted, tablet says update unsuccessful and revert to original settings.
So, i tried installing a custom bootloader, but when i download firmware from asus homepage, it comes up with message installation aborted, and with same exclamation mark.
Need help!
P.s.
i called asus and they told me that in this case they revert the firmware to the oldest and try installing a new one. But since i have the custom bootloader, im pretty sure my warranty is void, even if i unroot the device.
What you need:
plug in usb to pc.
Need help!
P.s.
