My Tf300t will not charge. I checked the lead, plug, the socket in the keyboard from the pins to the pcb, and the battery. They all test out ok. Is there anywhere I can get a replacement docking pcb, I think the charging circuit is goosed.
If you are trying to charge it when attached to the keyboard try wiggling them about a bit, because sometimes the connection can be a bit temperamental. What does the ASUS battery charge widget show when you are trying to charge? Does it show the condition of both batteries, i.e. tablet and keyboard? Does it show that it is charging?
Also does it charge if you plug it directly into the tablet rather than via the keyboard?
What charger are you using? Is it the original ASUS wall charger? A normal USB charger will not work because it only provides 5V and the ASUS needs 15V. Same applies if you are trying to charge it from your PC.
Original charger, no led activity at all on device. Wiggling connections does nothing. I could really do with a pin out diagram for the charging socket so I know where the voltages are, and if they go where they should.
