jon80
Member
Just dry running the code, and, I wonder why C:\ won't trigger the usual error message as there has not been a double '\\' as in the rest of the string.
## This file is automatically generated by Android Studio.
# Do not modify this file -- YOUR CHANGES WILL BE ERASED!
# This file must *NOT* be checked into Version Control Systems,
# as it contains information specific to your local configuration.
# Location of the SDK. This is only used by Gradle.
# For customization when using a Version Control System, please read the
# header note.
#Fri Dec 26 09:39:04 CET 2014
sdk.dir=C\:\\Users\\Administrator\\AppData\\Local\\Android\\sdk
(local.properties of a sample application).
See http://docs.oracle.com/javase/tutorial/java/data/characters.html and scroll down to the unlabeled table on backslash operators.
# header note.
