Those are normal.ok thank you for your input...I have not been unzipping the rom files but
When I first start in fastboot and it checks SD i get NO IMAGE OR WRONG IMAGE
and aslo when booting into recovery it hangs up on the HTC "this build is for development purposes only Do not Distribute etc...
Did you S-off?one more thing, in DOS on win I have been using the command...
fastboot flash boot .zip
then i get
sending boot OKAY
writing boot FAILED <remote image error!
