nickdalzell
Extreme Android User
when my S4 got botched up by my attempt at rooting in order to block the KitKat OTA from installing onto it (i expected it to turn into the iOS 7-inspired UI seen in the Galaxy S5--did not want) i had to replace it. given that i am eligible for Verizon EDGE, i got the Note 3--a phone i wanted for a long time. Of course, the model in the Verizon store had already had KitKat pre-installed onto it. after playing around for a bit, here's some of what i have noticed:
1. The white status bar icons--these are an annoyance, and super-bright on an AMOLED screen, so they might take getting used to. it sort of breaks the whole organic, earthy Nature UX look i have come to know and love, but can be ignored after awhile. the only thing i do wish is that it didn't make the email notifications change. before i had little logos to tell me which account the notification came from--i use Samsung's email client because of the UI and the multi-account support and custom sync scheduling, so i would get a little envelope with a 'Y!' icon for an email belonging to my Yahoo! account, one with a stylized 'M' icon for a Gmail message, and so on. now, it's just replaced with three redundant generic email icons with just a '@' in them, much like the same notification used in earlier versions of TouchWiz Nature UX. it has sort of gone back to the 4.1.2 style notification icon seen in the Galaxy Tab and Galaxy S3.
2. the app drawer has a bit more 3-D polish to the icons, again, taking cues from the earlier version (based on Android 4.1.2) of Nature UX seen in the Galaxy S3, Galaxy Tab and first Galaxy Note tablets. in a way i prefer it, as i did not take well to the more flattened icons in the 4.3 version, so this is a welcome throwback.
3. the UI is otherwise left alone. the Samsung Music app is just as polished as it was, the UI has buttons that still look like buttons, and Nature UX with exception of the colorless icons up top is left alone. Again, i prefer this
4. Battery life and signal seem improved, although the latter might be why the former is improved. i now get one or two bars and a 3G/1X data connection where i would normally have no signal at all. not a major difference but still, welcome. i never factory reset and yet nothing is amiss.
5. the icons, grid, and lock screen fonts are a bit better, smaller and fit the screen better. in 4.3 as seen from the S4, the icons were huge, oversized and only fit so well in the grid with tons of empty space between. this was ok if you often hit the wrong icon sitting next to the one you wanted, and this did happen often, but on a Note's screen this would be too much. so the fit to resolution is nice, too.
6. no ART support. in my view this is what really makes KitKat, KitKat. without it's just a version number jump. i have run KitKat custom ROMs on the S3 before (but always went back to stock as i never was too fond of basic Android) so i know it's doable, and the Nexus 5 has it, so this makes device #3 that never got it, even within Developer Options. a bit disappointing, and sad since even the Nexus tablets missed it.
In the end, aside the uber-bright hideous white icons (they are indeed loud) the upgrade feels more like a simple service pack than an upgrade. i for one am glad it did not put that hideous pastel UI that is seen in the newer Samsung products (Galaxy Tab 4, Note and Tab Pro, Galaxy S5) and can only hope that Samsung realizes that won't work and reverts before they do usher it into the Note 3 and earlier models.
I checked some demos of the iPads just to see if Jony Ive ever realized that iOS 7 was a mistake. i was quite surprised he had toned the flatness down. iBooks now reverts to the wooden bookshelves, the home screen icons have a bit more 3-D to them, even though stock icons are as flat as they have been, the 'frosted glass' has been eliminated, the stock Notes app now has a slight faux white leather texture albeit subdued, the icons in apps are no longer purple but green/orange, and other apps have skeuomorphic elements. that Air had version 7.1.1 installed, which is a few higher than my previous iPad 3, so if this indicates anything, Samsung might add in some of the 3-D to follow suit before long. here's to that, since i would hate to give up all my Samsung products for LG products.
Oppo, Xiaomi, Meizu, OnePlus, And all these OEMs actually encourage and supports users to modify and install their own ROMs on their phones. Guess which OEMs might get my future custom and those which may not.
