Help The phone writes that there is not enough place, although it is full there. What to do?
unaflores21
Hey! Tell me, please, I encountered such a problem, when downloading an application from Google Play, an error is output: "Failed to download the application. Not enough place in the device's memory. " At the same time, there is plenty of memory in memory - at least several gigabytes, while the amount of application is downloaded - just a few megabytes. What to do, how to be?
Thank you very much for your reply! Friends came to me and helped me solve the problem. I will try to describe the solution to the problem, maybe someone will need someone. Clear the cache for the Play Market application, you can do in the phone setting. Perhaps because I work best custom writing and I install and remove a large number of diverse applications for work, the cache overwhelmed.
