Help The same entry, multiple times in my calendar...?!
lexlowe
good Afternoon all.... wonder if i can trouble you for some assitance on this.
background info
- HTC Desire HD phone on vodafone in the UK.
Issue
The problem is with the calendar app that was preloaded with the phone; i have linked this to my gmail account, and it is also linked to my facebook account.
todays entry shows:
- 2 seperate events that were in my gmail account: this is all fine.
- 2 birthdays that were linked through my FB account, however 1 birthday is showing 6 times, and the other 4 times.
this is repeated for pretty much every FB birthday entry on my calendar.
The question:
how on earth do i reset / clear / change settings to ensure that in the FB accoun it shows each brithday only once, and not multiple times...!!???
if i go into the calendar app and manually change the 'calendars' that provide the info, and remove the FB one then it shows the correct entries from my gmail calendar - however if i then go back in and 'check' the FB calendar entry, it goes back to the original state and shows these 'birthdays' numerous times....v irritating!!
Can anyone help me resolve this??
cheers all,
I don't use the calendars, but have you tried clearing the data from them via the applications menu then resyncing?
Settings -> Applications -> Manage Applications -> Calendar -> Clear Data
It will yeah, but it should download all the events again when you resync. I think that just clears the local data.
I could be wrong though, as I say. I don't use the calendar widgets so before doing so, see what others have to say.
just done it - doesnt seem to delete anything from the local calendar on the phone....
hmmm....
tired re-synching the FB calendar and it still shows up individual birthdays a multiple number of times.... 6 in some cases..!!!???
I too am having this problem.
I have tried deleting everything & then re-syncing which at first works but after a while & a few link contacts requests the Facebook birthdays start to multiply again.
Does anyone have a solution to stop this happening it is really driving me mad.
Thanks
I think I may have sorted this problem out.
I went in Accounts & sync and then went into Facebook for HTC sense and then I pressed on remove account. This took all the birthday entries out of my calender but as events come from the normal Facebook account they were left there. I then went back into Account & sync and pressed on add account. I then logged back into Facebook for HTC sense which then brought back the birthdays into the calender but this time only one entry for each had appeared :)
I have deleted the calender entries before & for a little while I have had the correct amount of birthday entries. I think this time though I have fixed it for good. Only time will tell.
Removing & the the logging back in to Facebook for HTC sense has also sorted out the contacts pictures in handcent sms problem that I had too.:)
