skarface1988
((longer battery life))
the way I save my battery is by turning off my 3g/4g, wifi ((that if i dont use the internet or mms)) just texing, gaming, and music. i dim my display backlights ((if you are inside indoors)) , turn off all vibration, animation and uninstall unwanted apps. kill unused running apps.
((a way not to damage/drain battery fast))
let my battery die completely by when it can't turn on anymore. and do a complete 100% charge. i don't keep plugging in and unplugging out on and off. because it can mess up the battery...I recommend let your battery die all the way and do a full charge without break!
I just wanted to share with everyone else that's all. if you already knew about it AWESOME! but others may not know
