Theme for Swype
jxnrxy
Themes are converted from droid-life:
Link Removed By OfTheDamned
ok so when Swype stopped working I was truly disappointed. Then sed was able to find us another working app (which is greatly appreciated, without it this would not be possible), i was still disappointed that i lost my colored theme so, after some work and changing things up i give you some colored swype keyboards!!!
hope you like them! make sure to uninstall your current swype and then you can install any of these colors.
these took A LOT of time and they were a pain so please donate:D, anything including penny's will make my wife stop telling me I'm wasting my time and get off the computer haha!(don't deny it, your wife says the same thing)
Links Removed By OfTheDamned
Awesome, I was hoping someone would theme the new working version. Any way we could get something In black? Good lookin out
uninstalled previous swype, downloaded new blue skin. The swyping line is very stiff, doesn't flow well, and when i try swyping double letters, it's terrible. Any ideas? Love the color, but its a bit buggy
Try adjusting the settings....menu>settings>location and keyboard>swype settings>.....should find it in there.
I installed the Green theme. Thanks. I may be mistaken and I can't check it now because i uninstalled the other version but didn't the regular swype lite version have a third keyboard for advanced symbols? or maybe I am thinking of the stock keyboard. Does anyone know?
You need to press the Sym key and then press the arrow up and Sym again. That will take you to the keyboard that looks like a keypad.
Nice job with the themes, jxnrxy! I agree that a black theme would be nice. Also, maybe have the non-dominant lettering be a slightly different color? Maybe grey instead of white...that will help differentiate things a bit better. Keep up the good work!
This version has advnaced symbols as well. Hit the "sym" key then the "caps" arrow up key and voila!
Also, if you swipe from the bottom left key (the one with the swype hand symbol) ovber to the "sym" key you ket another keyboard with advanced cursor actions (select, cut, paste, page up, page down, home, cursor jump).
thanks ttran for the quick reply. I think I can manage to remember that and in that case will happily submit a donation to jxnryx for all his hard work. It looks great. Thanks.
Tried downloading, but when i selected download file just kept taking me to the same screen to download file?
did you uninstall your previous version and is this a beta or not?? cause i still have the other but im goin to be heartbroken again if this is just a trial.. i cant handle that type of emotional lost again lol :D
lemme kno:)
