Root [THEME] ICE10-CM7 build 20121027
inub
Member
If a mod would move this thread to the theme section of the forums that would be great sorry for the wrong section post to be honest i dont really care about making anybody elses phone look better than my fellow triumph users ;) so just keep it here in the triumph dev n root section if its not a big deal
What is Themed:
•Framework
•Browser
•SystemUI
•Contacts
•Phone
•SMS
•Settings/Power Control Widget
•Search
•Music
•News and Weather
•Deskclock
•Calculator
•Keyboard
Theme:
• UOT_Ice10_hdpi.apk (ics blue)
• UOT_GingerIce10_hdpi.apk (gingerbread green)
Flashable Theme:
• UOT-10-28-Ice10.zip (font change)
• UOT-10-09-GingerIce10.zip (font change)
Reported Issues:
•the grammar and spelling in my posts lol
•there is an error when applying this theme within the theme chooser app (just disreguard it and apply anyway)
•some calulator buttons seem to be missing?
•the custom background image that was put in for menus makes the text in the deskclock app unreadable
•the calender widget may have the same problem mentioned above
•the screen text color for the windows menu in the browser app is white on a white background making it unreadable (the icon for the site is still there and if u press and highlight it the text is readable)
Things to note:
•the main gray color is #262626 the blue is #33b5e5 and the green is #a4c639
•if anyone has any ideas on how to easily fix or would like to help with any of the reported issues please feel free to post
Credits:
•this theme was based off ICE9 and most of the credit goes to jasonevil over at xda
Messed up the calendar widget for me
i didnt see any changes to that widget but then again i dont use it alot so that is something that must of came with the orginal theme i modified ill take another look at it and see if i can change it no promises tho im still really new to themeing
I like black too better than the gray its just the color the original theme was using n I thought it was a nice change of pace on the eyes if u really like this theme ill see if I have extra time maybe I change out all the grays for ya I need more experience anyways
I like black too better than the gray its just the color the original theme was using n I thought it was I nice change of pace on the eyes if u really like this theme ill see if I have extra time maybe I change out all the grays for ya I need more experience anyways
Theme looks great man. I like the gray. It's a little different than the other ICS themes and there's nothing wrong with that!
Hello there! First off I'd like to say this theme is awesome! Its currently my main theme. But I'd also like to make two suggestions if you don't mind. It's just little things that would be cool to add.
The first would be the loading circle. It would be cool to have the loading circle from g60's Cynocream theme. I feel like it would give it a more ice cream sandwich feel. And the second thing that would be great to add is changing the play store theme to blue instead of green. It would be awesome to have matching colors since its a blue based theme.
the loading circle i can do the play store however is a lil more complicated if u would like one that has ics blue instead of green there are a few floating around. here ill find u the one i use
https://www.dropbox.com/s/78onpnc8p1boznh/InvertedPhonesky.zip
https://www.dropbox.com/s/di2m1pbu7m4zlam/InvertedVending.zip
1. Make a folder on your SDCARD for Gapps.
2. Download both inverted
3. Move both Original market APKs from the system apps to the folder you made on sdcard
4. Reboot into recovery
5. Flash Phonesky first then Vending
6. Reboot!
Source:
all these apps here are for gingerbread so have at it
Gingerbread Inverted Google apps![Updated 7/6/12]-Market update! - xda-developers
Maybe but it only happens when I have this theme installed
ill take another look into it n do some tests pretty sure its something on ur end tho bc i have installed this on three triumphs n i have yet to even see the 2g icon
Im also getting the 2G glitch, plus when I installed it gave me an error about screen size but I applied the theme anyway and everything looks the screenshots with the exception of the bar at the bottom of the screen, yours has four icons and the app dock icon, mine has only call, app dock, and browse.
Also when in the internet browser, if you view your tabs the font is set as white so you cant read any of them.
well you've tried it on 3 triumphs, I've tried them on 2. while idk if it a bug or not, but that's the only issue I've seen with his theme nothing else.
thanks man i like feed back and i like this theme and if u guys like it too ill do more research and continue to fix a few more of the things wrong with it im not a pro themer tho i didnt do half the work it took to make this theme someone else did im just customizing it a bit more to my liking and giving it some love in other places so the things i do i have to research and then trial and error but i dont mind it gives me something to do when im bored plus everything android intrigues me :)
the error when applying the theme is normal dont mind its pretty piontless my guess is that the theme app that comes w most these cm7 roms aint reading the theme file correctly or that the theme file is missing a bit of code somewhere that tells it what screensize and density the theme itself was made to run on my guess is and how i understand it is that using themes for a different screen size can corrupt your rom and even brick your phone so thats why the error reminder is there but this theme is for hdpi resolution screens like our wat triumph has so it is safe to apply
the app dock i use is "adwlauncher ex" with an ics theme for it i use the paid version but the free one on the market is just as good and very customizable but i like to change my dpi and with the donate app you can change the size of the icons and the label fonts so they aint super tiny with a really low dpi value
i did see the 2g icon today when i got an mms from some chick sending me naughty pics lol so it is there but she wouldnt send me any more lol so thats the only time i seem to have got it im usually on wifi n if i turn it off all i see is the 3g icon maybe somebody with more experience with themes can shine in and help bc i checked and all the icons seem to be right but maybe its just the icons themself idk i could try to change them to something different and maybe that will fix the issue but ill need one of u guys to test it for me if u would bc i dont seem to have the glitch u guys do or just cant replicate it without more info all the 2g icon is replacing is the 1x icon so if u disable this theme and do exactly what gave u the 2g icon w it applied and see 1x instead then its not the theme or icon its the rom or your service but ill change just that icon to something different which will only take a few minutes when i have just a lil more time n ill post an edit here and tell me if ur still seeing it id do it now but i have wasted most of my time to reply to this thread and explain a few things :P
about the tabs in the browser im gonna have to change some things and hope it gets that text to a different color again if someone else reading this can help please do u will save me time bc alot of fonts and their colors are tied together across multiple apps so it can be really tough to get them all readable on different backgrounds i believe thats wat the issue is w the calender widget too all i can say is i will try bc i like this theme as much as everyone else and its what ill be using till i find better so i want it to be perfect right along w u but i cant promise anything bc im still learning :)
fixed a few of the issues along with the 2g shit lol and updated first post with a green version the rest of the issues i cant seem to fix i tried so i also marked this as final
Did anything change in the gingerice theme? It looks the same as the original gingerice 9 theme!
i uploaded the wrong one but it looks almost exactly like the one picture on the first post but w green the zipped one is fine ill fix the link now
Yeah I just redownloaded it. Dude its sweet!! Is the uot kitchen hard to use? I'm thinking bout cooking me up a cm7 theme!
