Root [THEME] - ICS Theme For CM7.2 + With Extras
Killah1994
Android Expert
ICS Theme For CM7.2 + Extras
Features :
ICS Transitions
ICS Fonts
ICS Color
ICS CM7 Status Bar Toggles
ICS Settings (Without Toggles)
And Also A Undo.zip to restore stock settings
Themed Apps :
Holo Launcher
Go Launcher ics theme
Tapatalk
Bluetooth File Transfer
& More ;)
How to install :
1. For the ICSandwich[FINAL].apk install like a regular app and apply it in Theme Chooser
2. For the ICS.Settings.zip - Head into recovery and mount system then install (dont wipe anything)
3. For the Undo.ICS.Settings.zip - Same as how to install the ICS.Settings.zip
ICS Theme - ICSandwich[FINAL].apk
ICS Settings - ICS.Settings.zip
Undo ICS Settings - Undo.ICS.Settings.zip
By Killah1994 & Vikasb32 With Love Enjoy ;)
Screenshots :
Use holo launcher for a sexier look of ICS
NOTE
Only for cm7.2 .... if tried with any other rom it will work but certain options in settings will force close !!
Credits
Vikasb32 - theme & settings
Killah1994 - (tweaked the orignal theme & settings)
Ok not to bring you down or anything but your theme sounds and looks very similar to this ics theme on xda : [CM7 Theme][MDPI][Updated July-2]Complete ICS Theme With Different Colors - xda-developers along with the undo ics thing and the things that are themed. Now if this is legitimately yours then i'll leave it at that. But you shouldn't take credit for other people's work if this is what this is.
hhmm it does look erieely similar now that you point it out kage. if you kanged the theme then atleast give credit to where it due, but seriously dont take credit for someone else's work. ill you the benefit of the doubt killah
Its the same theme but i changed some pics in it
And yes credit will be given lol but i did edit the settings some more though
Im not that mean
