Lordvincent 90
STANDARD DISCLAIMER- I AM NOT RESPONSIBLE FOR ANY DAMAGE TO YOUR DEVICE, REPUTATION OR EMPLOYMENT STATUS AS A RESULT OF USING THESE THEMES.
THESE THEMES WILL WORK WITH STOCK DEODEXED BASED ROM.
AS USUAL MAKE A BACKUP BEFORE FLASHING THIS, SO YOU CAN REVERT EASILY IF YOU'RE UNHAPPY WITH THE LOOK.
SMILES:
DARKNESS
[Hide]
-Battery Guage
-Centered clock (made blue too)
-Emoticons
-Notification Shade Toggles
-Settings Background Image
-Signal Bars
-Skull Themed Hidden Image/Easter Egg (see video)
-Wifi icons
--themed most notification icons blue
More to come
to install:
-download to sdcard
-boot into recovery
-select choose zip from sdcard
-select install zip from external/sdcard (whichever you saved it to)
-select Darkness-2.1.1.zip
-select yes
Screenshots:
[Youtube]T2s2vpyNOlk[/Youtube]
Download Link
Darkness 2.1.1
Old versions:
[Hide]
Butter Theme
Darkness Theme
Darkness-2.0.0
[/Hide]
change log
[/Hide]
SMILES:
-Battery Guage
-Emoticions (now scaled down to fit phone better)
-Signal Bars
-Smile Themed Hidden Image/Easter Egg (see video)
-Wifi Signal Bars
More To Come!
to install:
-download to sdcard
-boot into recovery
-select Smilez.zip
-select yes
[Youtube]p_ejMPTdfiA[/Youtube]
LINK:
smilez2.0.1
Stock Theme (9 Panel)
____________________________________
Old Version:
-Thanks to zjones for the deodexed base apps and K Rise/Zenwafer for Stocker
-Signal Bars
-Wifi Signal Bars
More To Come!
to install:
-download to sdcard
-boot into recovery
-select Smilez.zip
-select yes
LINK:
smilez2.0.1
Old Version:
DARKNESS
[Hide]
-Battery Guage
-Emoticons
-Signal Bars
-Wifi icons
More to come
to install:
-download to sdcard
-boot into recovery
-select yes
Screenshots:
Download Link
Darkness 2.1.1
Old versions:
[Hide]
Butter Theme
Darkness Theme
Darkness-2.0.0
[/Hide]
change log
Code:
butter theme
-inital release
-darkness 2.0
-Centered clock
-added emoticons
-edited most notification bar icons
-themed WiFi and signal bars.
-changed brightness slider icon
-changed quick settings icon
dakness 2.1.1
-added transparency to notification pull down
-brightened up clock to make more visible
-colored clock in pulldown
-colored toggle text
