Root [THEME][WIP] Ice Cream Kangwich [2.7.12]
KaneOfMars
Member
Ice Cream Kangwich - Theme
This does not work on ZVD!
*Please keep in mind this is a work in progress....
You can donate if you like, but it is not necessary :) Click Here
This is for GingerSteem Extreme
ICK v1.2 for GingerSteem Extreme w/ Stock Battery
Change Log:
- Added Stock Battery w/o % (Battery is still accurate) :D
Change Log:
- XML Edits (hopefully fixed the clear button and expanded menu text color)
- Fixed GPS Icon ... I hope :P
- Borrowed Settings.apk w/ the Bluetooth fix from ldrifta's LD-ICS ROM
*If these edits work, I'll upload an alternate version with the stock battery icons :D
ICK v1.1 for GingerSteem Extreme
Change Log:
- Fixed Handle Bar for Notifications (3rd time's the charm?)
- No More GPS Privacy Icon
- Adjusted Size of a few Status Bar Icons
ICK v1.0 for GingerSteem Extreme
Change Log:
- Fixed WiFi and Data Icons to show blue all the time
- Hopefully Fixed the Handle Bar for Notifications - fail!
- Deleted the Annoying GPS Privacy Icons (if you prefer to have them, let me know) - fail!
ICK for Gingersteem Extreme Beta (this release was not tested, status bar may force close ... please let me know)
What's themed so far:
- ICS Status Bar Icons (kept the default mobile data icons)
- ICS Notification Txt Layout
- Misc. Menu Icons
- Expanded Status Bar Toggles (I didn't make these, still working on getting mine ported over)
- Settings.apk
Screen Shots: (Courtesy of ldrifta)
Thanks to Sergio19r, twistedriku, budde2, jzebrahockey, guaterican101, and ShineySide for testing this for me. (if I missed anyone, let me know and I'll add you to the list)
I've tested it out, is pretty good... The settings apk and menu isn't themed the battery seems huge but other than that... It's a great start
It looks awesome ! Only theres one problem that i found so far .. when turning into landscape, the status bar is too big . lol It doesn't fit the screen anymore. Awesome work though !
awesome, I can already see a few things from the screenshots that need to be fixed.
thanks everyone for reporting back so fast :D
edit: believe it or not, the battery icon is smaller than what it was originally :P
I did notice that when wifi is off the signal bar turns blue. When it is on it turns grey. So does the wifi bar. Please fix if you can. Also when I go into apps and go into their menu or settings the bar that comes up, root explorer for instance, when I click for the menu and go to more there are many options there but the bar is black and so is the text so I can't see what is there. Is there a way to fix that? THank you.
will look into the black txt, mine shows white ... will need to figure out where that is located.
working on the status bar icons now
cwm-install zip from SD?
yes, sorry for the lack of instructions :P
im testing this soon as I get home... wish I didnt bother making a thread, we can put our work together and make a sweet ass theme lol I make terrible decisions sometimes... let me know if your interested.. maybe we can do something..
btw feel free to use anything you need from my version
sounds great!
