Well I think I dodged a bullet.
My first OM was perfect. 2.2.1. rooted with custom recovery and overclock kernel. Everything worked fine. Only a few minor issues with updating the SU binary but NO rebooting it freezing issues what so ever. But then while taking the sd card out (usually use the USB) one of the small golden pins broke off. Thinking I was screwed got me worried...SD card wouldn't read and more, not to mention half my apps were moved to it! So even though I still had root and overclocked stock kernel (768 max), it wasn't good enough broken with no sd card. Very limited with no sd card!
My friend had an Optimus (manufactured same year/month) and gave it to me. I had already rooted it a few months prior and removed the bloatware. Stable at 825! I didn't flash recovery or kernel. SADLY it suffered from the stupid annoying reboot, freeze, force close problems people are complaining about! I flashed joneidys recovery and the stock OC kernel and still suffered from the problems.
I took my original working Optimus apart to see how the sd slot was attached to the board and it was only four small.solder points that I could see. So I thought about desoldering the sd from the rebooting one to the broken one. Keep in mind I don't have an iron and don't have much soldering experience. lol
So the next morning I wake up and decide to try to bend the prong in hopes I could revive it. I ben it upwards slightly with a mini screwdriver and out the card in. IT SAID MOUNTING SD CARD. I couldn't believe it, made my day. Even though I'm down $20 since I switched numbers twice! And my original non rebooting one has a lower stable threshold for overclocking. (768 vs 825)
So I got it back and running luckily and it hasn't rebooted once! I haven't flashed any roms yet as I don't fully understand it and what to backup, delete and how easy it is to go back to my stock setup with my apps, kernel and recovery. Do the recovery and kernel get replaced when flashing a custom rom? What about flashing the stock LG rom or downgrading?
Only issue that I keep getting is Superuser's su binary wont update to 3.0.3 from 3.0. I have tried the updated fixer and it finds nothing. It says ok for everything and superuser grants access and it fails after asking for root access. But the toast notification comes up that says it was granted access. I forogt the superuser permission,tried again and still happens. Any ideas? Is supersuser something you can just uninstall and reinstall a new one from the market?.Sorry for the noon questions but searching isn't so great using the phones "3g" signal...
Sorry for such a long post (posting from my phone atleast) but im just curious about the superuser issue now.
