This would work with 3g right?
you might have to do some searching to find a site that ships to us. if i were you and you dont need the keyboard, i would go with the ATT nexus one. its cheaper and you will be able to get updates faster than the milestone
I would prefer the physical keyboard..
but, I the nexus one would probably be a better bet anyway... I could live with n1.
Honestly if n900 had 3g I'd hop on that.. However, I must admit android grows so much faster.
No 3G T-Mobile service in your area? You could do voice and data for $40/mo "total", on T-Mo. Throw in "Skype-Out", for $3/mo more, and you can get unlimited "outbound" calling. That or add-on any existing SIP client.
Only problem I have with T-Mo and the 900 is poor/no reception in certain buildings...looking at going back to AT&T. FWIW, I had even more reception issues with the Droid on Verizon (made an antenna mod which helped a lot).
Nokia is supposedly coming out with an N9xx later this year...may be AT&T 3G compatible, running the new "Meego" OS.
