A Android Question Guest Nov 13, 2014 #1 How do you remove unwanted software from the "myTouch" stinking Android TMobile sells? Won't give option at all in App Manager. thanks
bkttk2 Android Enthusiast Nov 13, 2014 #2 Android Question said: How do you remove unwanted software from the "myTouch" stinking Android TMobile sells? Won't give option at all in App Manager. thanks Click to expand... In order to remove preintsalled apps you do not want (bloatware) you will have to root your device. Look through the forums for your device for assistance with rooting if you choose to go that route. Hope this helps bkttk2
