Thanks everyone.
I tried restoring "[SMS/MMS/APN] Dialer Storage 2.3.4" and that did not bring them back.
I'll give SMS Backup and Restore a try.
I'll give that a shot too.You have to reboot after restoring.![]()
TiBu does work when you reboot.![]()
I'm having the same issue with SMS backup as I do with MyBackup Pro.
All the messages are there, but they all have the exact same timestamp.
ie, all the restored messages show as being sent/received at the time they were restored.
MBP does keep them in the correct order however, SMS Backup seems to be grouping all of the sent and received messages together so it looks like a one sided conversation.
Is there a trick?
So this might apply as well to our BIONICs?NOTE: There is a known problem with some firmware versions of the Droid X and Droid 2 phones that the restored messages do not get the correct time stamps.
Q21: I have a Motorola phone and when I perform a Restore, all the messages get the time of restore rather than the actual time of the message. How do I fix it?
A: This is a problem with some versions of some Motorola phones that they do not accept the time stamp supplied when restoring. Some users have reported that sometimes its caused by using the “SMS Time Fix” app and disabling it while restoring fixes the problem. However, its more likely that its caused by the way the Messaging app stores and reads the time stamp for messages. I do not have access to these phones and hence I haven’t been able to try and find a work around for this problem yet.
If you are willing to help and have a rooted Motorola phone and have this problem when restoring, then please contact me so that we can try to find a solution/workaround.
A few users have also reported that using third party SMS apps like Go SMS works better and it shows the correct time stamps.
Absolutely.I'm definitely rooted, and I'm pretty positive you are also. Want to tag team and help him figure this out?
Have you heard anything back?I already posted a comment under the FAQs about wanting to help, and I used my AF Profile as my website.
