time/weather widget issue
  • Start date Start date
A
Android Question
Guest
First I noticed the time was wrong and discovered the location said Gaborone, which is in Botswana.
I am in Maryland, USA and have deleted the cities I had selected, none of which is Gaborone, but Gaborone
doesn't appear on my selected list disabling my ability to delete it. Think I've been hacked. Any help?
Try deleting the widget and adding it back. Or uninstalling and reinstalling the widget/app. Worse case scenario, do a factory data reset.
good luck
