raphapablap
Hi,
Newbie to the forum and I have a problem with my HTC Incredible S picking up the correct time on the Clock app since the time has changed to CEST.
A bit of background. I live in Gibraltar, which is on the same timezone as Paris/Rome/Barcelona, so when the clocks went an hour forward recently, the Clock app should have moved to +2 GMT, however currently it is still stuck on +1 GMT.
The main issue is that the WeatherClock widget displays the time of GMT +1 whereas the actual clock in the top right of the screen displays GMT +2 time.
If I go to the Clock app and select the World Clock option, I can see that Barca/Rome/Paris are all displaying the correct time, whereas my current/home time is incorrect.
From there, if I select "Local Time Settings", I can see the Automatic option is selected (use network-provided values). Deselecting that, I can change my time zone to GMT +2, which it should be, my phone then displays the correct time on the WeatherClock widget, but the top right hand corner clock displays the time as GMT +3 (while also showing Rome/Paris/Barca as GMT +3 also).
I thought it may have been an issue with the Weather section so I went to the Maps app, let the GPS pick up my location, then went to the Weather App and saw that it was displaying the correct time. I refreshed to make sure and it stayed the same, but going back to the WeatherClock widget it still displays the wrong time!
I hope what I have written makes an ounce of sense and that you guys can help out
NOTE:
I'm using the WeatherClock as an example, I've tried the other Clock displays and they all show the time incorrectly.
NOTE:
