S snakeybidder Well-Known Member May 29, 2010 #1 Is there a way to set gmail app to check for emails every say 15 minutes instead of push ??
J jmcgee_jr Newbie May 29, 2010 #2 I do not believe there is. However push shouldnt be draining your battery.
S snakeybidder Well-Known Member May 29, 2010 #3 jmcgee_jr said: I do not believe there is. However push shouldnt be draining your battery. Click to expand... Its not really but i thought it would save more no?...o well
Markdental Member May 29, 2010 #4 GMAIL does not drain battery to check because gmail will send you your email when it gets one on its server. Your phone isn't "looking" for new e-mails every X minutes. BIG difference. It cannot drain any less.
S snakeybidder Well-Known Member May 29, 2010 #5 Markdental said: GMAIL does not drain battery to check because gmail will send you your email when it gets one on its server. Your phone isn't "looking" for new e-mails every X minutes. BIG difference. It cannot drain any less. Click to expand... Ok cool, thanks for that
