Hi-figured I'd try here to see if someone can help me with my problem. I upgraded from an original Droid to the Razr Maxx, and copied my old card onto a new, 32gb card when I installed it. I seem to have inadvertantly created a partition, with a small section labeled "SD card", and a larger one "ext-SD card". The one labeled SD is the one the phone assumes is the "real" SD, so downloads and moves apps there. It only has 8gb, which have filled and now I can't download apps/media/upgrade, etc. I have titanium pro, have rooted the phone, but still on stock Razr ROM. I'm not sure how to use Titanium for this...purchased a Sandisk 64gb card, which I've read can work and is marketed as compatable with android. Can I change cards and somehow repopulate it properly with Titanium (and how)? Should I reformat old 32gb card, then use Titanium to repopulate without a partition (and how). Is there another, better way to do this?
Thanks, hope someone can help.
