thanks for the fix.I had this issue as well and was able to fix it with this app from the app store(requires root): https://play.google.com/store/apps/details?id=nextapp.sdfix&hl=en
I think you can do this manually, but the app made it much easier.
Zach just use the app SDFix that portezbie posted the link for.
It makes it so apps can save to SD card. Give it a go; it fixed my problem.
