Titatanium Backup and how to root it??
altkon
Tried to run Titanium Backup but wants root priviledges and I dont knowhow to do it.:o
Perhaps because we have tried it without having connected the 2 devices - PC and APad - with the Usb cable.
Appriciate if you can guide us on this issue please.
Thanks again.
Regards,
Andre
You don't root the app itself, you root your phone, then use Titanium to backup your apps. Go to the specific board for your phone. There should be a sub-forum for rooting. You'll find the info you need there. Keep in mind rooting will void your warranty.
Is the guide on this link the solution to my problem??
Titanium Backup: For Root Users
Before you can install Titanium you first need to "root" your phone which is an entirely different procedure to Titanium.
More info here:-
http://androidforums.com/android-lounge/12585-what-rooting.html
http://androidforums.com/motorola-droid/31542-what-does-mean-root-your-phone.html
Remember... the search button is your friend.
Hope this helps. :D
Rooting your phone gives you superuser access - sort of like an admin account on a Windows machine. It's not a trivial thing and shouldn't be undertaken until you understand the process thoroughly. For unrooted phones, I think MyBackup is currently considered the best backup solution.
