To format and re-install android os
  • Start date Start date
A
Android Question
Guest
Can I make format any Tablet and can I able to install a fresh android os in to that Tab?
if yes then pls help me in this regards and guide me the steps to do it....
Hi
I think what you are asking how to do is a factory reset of your tablet. This wipes everything off it and reinstates it to its "as new" condition with a fresh install of the OS and apps. ( It will not return it to "as new" if it has been rooted and has a custom Rom installed )
from the home screen
menu
settings
backup & reset
factory data reset
Note that this will delete everything from your device so back it all up first!
If you are asking how to root devices and install custom roms then its a complicated subject and the method differes for each different device. I suggest you research the method for the particular device you had in mind.
Hope this helps
Roger
