joesweeney0424 Lurker Apr 21, 2017 #1 Hi, just got the lgg6. Can u change the pull down toggle menu to black. Thanx in advance
R rkingsparx81 Lurker Apr 21, 2017 #2 You can if you select a theme that has a black pull down. I use the pixel dark theme from the play store
joesweeney0424 Lurker Apr 22, 2017 #3 rkingsparx81 said: You can if you select a theme that has a black pull down. I use the pixel dark theme from the play store Click to expand... Last edited by a moderator: Apr 22, 2017
