Tokio Tablet
Mods if this is in the wrong section please feel free to move.
I am pretty much a newbie with Android and the whole rooting business but after a few heart stopping moments I have been able to root my Gallaxy Tab and my HTC phone in order to install a custom Rom.
A friend however has come in to me with a really cheap tablet which he won called a Tokio Tablet 1.0 which is currently running 2.3.1 right from the start he has been having problems and when it boots it comes up with an error saying "System UID Inconsistant" and suggest that the operating system is reinstalled.
Now there is nowhere I can see where you can do this. Reseting the machine does not solve the problem and I was wondering if it would be possible to root the thing and install a custom rom. But saying that I cant see how you would even go about it.
Searcing the web has brought zero results so any solution would be gratefully received otherwise its for the bin.
Thanks
Thanks
Is it this?
Tokio Tablet | SEGA Amusements
When you say you reset it, do you mean you performed a factory reset from the phone's settings?
I don't know anything about that tablet... But there are a couple root methods that might work.... One is called "gingerbreak"
[App] [26.04.2011][v1.2] GingerBreak APK (root for GingerBread) - xda-developers
Yep that is the tablet.
Yes the factory reset was done via the settings. Apart from the round button on the front of the device there is only one other "power on" button at the side.
I will have a look at the link provided..many thanks
Just been informed by the owner that it is nearly impossible to get onto the settings screen so that has probably scuppered the above solution as it is unlikely I can select USB debugging.....still I will persevere.
