TomTom not allowing a 7 digit Postcode search.
Hi there,
I have a couple of Android devices - an HTC One X and a Samsung Note 10.1. My wife uses a Nexus 7.
I have installed TomTom UK and Ireland - it works perfectly, however it will only allow the input of the first 4 digits (i.e. BS29 ) of the postcode rather than the full 7.
I have googled this, and have found it's something to do with the folder named "zip" which is the Postcodes, however all the answer I can find is that this folder needs to be at the ROOT of the SD card. My OneX doesn't have a SD card, so on this device I've put the folder directly in the "Internal Storage" folder where everything else seems to be - On the Samsung Note I have put it at the root of the SD card.
Still not working - any ideas??
Called TomTom but they just keep telling me to put it at the root of the SD which I've done - no help....
