Root Too many problems with my One V...
rickyx32
So the problems with my rooted One V keep adding up... Today the alarm failed on me, I noticed that the screen was off but that the back light was on as I picked it up. Also, when I tried charging, it only when up to 78% so i had to push the power button for ten seconds for it to register a 100% charge... I also feel that it is a bit laggy for it to be working properly at 1.402ghz when compared to stock speed...
I posted on another thread about the problems I've been having with sending and receiving text messages, so putting all these things together what should I do? Should I forget about keeping it overclocked and switch back to the stock kernel? Should I try another ROM? I can also get a replacement from Amazon since it's been less than a month that I bought it, but would they be able to tell that I rooted it, do they even check... What do I do???:confused:
Return to stock and don't root again, rooting is dangerous at an unknown scale.
