You must be in DFU mode to use the tool. No other mode will work.Also I made the bootable disc of the tool I'm running the tool and I just I'm constantly getting device not detected device not detected I get the same thing in the adb shell
nope made usb stick rebooted my pc into the desktop ran the tool it said device not connectedYou must be in DFU mode to use the tool. No other mode will work.
Don't worry about the cache errors. Wipe data and flash a ROM and you should be good.SuperR thank you for your work on this project I made it into dfu ran tool said was unbricked the phone now boots to philz recovery and says r: cant mount /cache/recovery/command and there is a small list of cant opens all from cache I tell it to clear cash it stays on that screen forever I feel I have made progress though
This tool will only work in DFU mode.I have successfully gotten the the linux home screen but get "Device not detected" when entering the prompts. My problem is that this phone is stuck in recovery mode. I cannot get the phone into DFU mode. I have tried volup/down + power and get no results.
I understand that but I cannot seem to get the phone into DFU mode.This tool will only work in DFU mode.
How did you get it to stop saying cannot detect device because mine is still saying it?It said "your device was not detected"
DISCLAIMER: By using this tool, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.
For Boost Mobile ZTE Max N9520 only.
This is the ZTE Max Unbrick Tool
Download stormer_test_unbrick.iso
Use your favorite burning software to burn the iso image to cd. I like ImgBurn for windows because it is free, easy, and effective. Once the cd is burned, put it in your pc and reboot. Enter into your pc bios and change the boot order to making the cd drive the first to boot. Normally to get into pc bios, you need to press one of the following: del, f2, f10, or f12. It depends on the pc but it is normally right after the pc starts and it will say on the screen which one to press.
Once you get it booted on your pc, put your device in DFU mode (hold both volume buttons along with power). Plug in your device, click the green android icon on the desktop, press ok or enter on the password prompt, type "stormer" which is the codename for your device (you will see a chart) and press enter. Confirm with "y" then press enter, and wait.
Personally I make bootable usb flash drives instead of cd's. There is a program called Unetbootin that makes the process very easy.
Credits:
cooldudezach - figured out the partition locations
The password is "root"The password isnt right. could you pls put the right one ?
So i type Login: stormer password: root ???The password is "root"
