[Tool] GPS Signal Widget
  • Thread starter Thread starter handy5876
  • Start date Start date
H
handy5876
Guest
ss-480-1-4
Description
GPS Signal Widget 1X1
Do you get tired waiting for the GPS location to be available? With this tool you can check out the GPS satellites and the signal strength in just a nice 1X1 widget.
The spokes in the widget represents the satellites and the length of the spokes is a measure of the signal strength.
Enable or disable the widget by tapping on the widget. Generally keep the widget disabled to conserve battery.
New users - This is a widget. Select Menu>Add>Widget>GPS Signal Widget to use it.
Email any feedback to me.
v1.1
UI Changes
Reduced minimum API level to 7
v1.2
UI Changes
Tips
v1.3
Update rate of widget
Battery save policy is with user now
v1.4
Overhaul of code
Background color chooser
v1.5
UI Improvements
code optimization
Market Link
https://market.android.com/details?id=com.cls.gpswidget&feature=more_from_developer
