[Tool] Network Signal Widget
  • Thread starter Thread starter handy5876
  • Start date Start date
H
handy5876
Guest
Do you need a more precise way to know whether you are in a good signal environment? Is the default 4 signal bars shown by android not enough for you to judge whether you can make that important call?
Use this high resolution graphical widget and get a good idea of the signal activity in just a simple 1X1 widget without taking too much space.
Here is a rule of thumb for signal strength:-
Greater than -90 dBm - Good
Between -90 to -100 dBm - OK
Between -100 to -105 dBm - Not great
Between -105 to -113 dBm - Bad
-113 dBm is the bottom(noise floor).
Click on widget to disable it if you want as a battery saving measures.
Background color chooser including transparency
Market Link
https://market.android.com/details?id=com.cls.networkwidget&feature=more_from_developer
ss-480-0-2
