Root [TOOL] Recovery-Flasher
Swisaiahag
EXTRACT FOLDER
RENAME DESIRED RECOVERY "RECOVERY.img" EXACTLY AS SHOWNED WITH ("") OF COURSE .
PUT YOUR DEVICE IN FASTBOOT MODE.
FOR (HUAWEI-M835,C8150,U8150) HOLD VOLUME DOWN+END CALL KEY AND TAP POWER ON . HOLD FOR 7 SECONDS
FOR (HUAWEI-M835,C8150,U8150) YOUR PHONE WILL STAY ON HUAWEI SPLASHSCREEN .DONT WORRY ITS NORMAL
TAKE YOUR USB CORD AND PLUG IN THE COMPUTER END FIRST THEN THE PHONE END
WAIT UNTIL DRIVER SOFTWARE INSTALLATION IS COMPLETE
WHEN IT IS DONE RUN ALL FILE FOR YOUR COMPUTER
EXAMPLE: I'M USING WINDOWS 7
SO I WOULD DOUBLE CLICK : 1"adb-windows"
2"fastboot-windows"
3"install-recovery-windows"
AFTER THOSE THREE COMMANDS HAVE BEEN DONE YOUR ANDROID DEVICE WILL REBOOT .
use at your own risk . i am not responsible to anything you do to your android device. if you cannot boot into recovery
your download was corrupt or the recovery isn't compatible with your phone. also you have to go about another way of flashing recovery.
ONLY TESTED ON "HUAWEI-M835" ..
This What The README.txt Looks Like
what recovery does this flash? do we rename the recovery "RECOVERY.img" with the (" ") and all?
yes and it flash any recovery you want just rename RECOVERY.img and run the fliles for your system
1"adb-windows"
2"fastboot-windows"
for windows
No Prob. This was made for you to use it for any recovery ...UltraJack,Cwm, etc you can flash any recovery for m835 using this tool . all you have to do is rename it RECOVERY.img and run files for your system
im trying this. i can never seem to get it right.............
i rename it RECOVERY.img, i use the three commands
and nope
What system are you running ..did you extract the recovery flasher your desktop... it only works when you extract the folder...
