[TOOLS][2.3+] 3G Manager
3G Manager
MsF3gkZl_gN1LjgJWFCeZPab764M8JUvFLEGRYieWgVhD0q_sFuFb3oQ1I7wkd28HeI=w124
3G Manager allow you to save battery and avoid excessive Electromagnetic exposure by automatically disabling mobile data connection when you lock the screen.
The manager allow you to keep receiving notifications by automatically re-enabling the connection from time to time for two minutes to permit sync.
You can specify the reconnection interval and other settings.
Features:
- Automatically disable mobile data on screen-off
- Automatically enable mobile data on screen unlock or screen on
- Automatically disable mobile data and governor when WiFi is connected
- Delayed disconnection on screen off to allow rapid chatting
- Periodic reconnection to allow notifications
- Specify first reconnection time (before periodic reconnection)
- The manager will be autobatically paused while: charging, calling, on airplane mode and on Tethering/Hotspot mode
- WidgetLocker support
- Automatically disable mobile data while calling (optional)
- Governor on/off Widget (1x1)
Coming soon:
- Ask us for new features ;-)
Note: to maximize battery saving set higher re-connection interval or totally disable it (you will lose notification)
This application DOESN'T HAVE internet access permission.
Network communication permission is only for mobile data switch and detection.
Tested on: Nexus S, Galaxy Nexus, Galaxy Note, Xperia U, Galaxy S
Works also on CM9 and CM10
FEiyauaCpACp90egm3AzVPCKHH5b4i1KBhPCLPMgdC-KovWctP7nbdEs7J8Bx77yDyc
[UPDATE]
- Pause manager while Teather/Hotspot
- Disable mobile data while calling (optional)
- Bugfix and optimization
- New app name: "3G Manager"
