Hello
Easy Calculator Pro -very powerfull but simple calculator for everyday.
Unlike ordinary office calculator Easy Calculator Pro lets you perform complicated expressions always keeping an eye on the input data.
Easy Calculator Pro can work with constants, mathematical functions, supports operations with dates and time periods.
Features:
* Expression calculation.
* Calculation history.
* Advanced percent calculation (Discounts, Tax, Tips).
* Precision up to 30 significant decimal digits (may be increased)
* Advanced result formatting. As: numbers, dates, percents, hex, oct, bin .... representations.
* Expression syntax highlight - easy reading.
* Exact error highlight - easy correction.
* Extended functions.
* Date and time operations
* Radians and degrees with Degree-Minute-Second (DMS) feature
* Saving state between sessions.
Here some examples.
It helps you to find out how much the tip should be on your order.
Just summ all order items and add a tip value
2*1.5 + 7 + 12 + 10%
or just
2*1.5 + 7 + 12 + 10% ) / 2
for two persons (opening bracket is not required)
You can use it as engineer or scientific calculator
√(G*Me/g) - returns the radius of the Earth.
Or just for date or time calculation.
To find out what day will be in 40 days after the 1st of May.
date(12; 05; 01) + 40
You can see that day in short (10/05/12), medium (jun 10, 2012) or long (Sunday, June 10, 2012) format.
It is easy to change result view:
1. Touch and hold result line to see action menu:
2. Choose 'View' - you will see all available views - choose one you like
History
Easy Calculator Pro
on play store:
https://play.google.com/store/apps/details?id=com.msj.easycalcpro
or market url: market://details?id=com.msj.easycalcpro
Features:
Here some examples.
or just
History
Easy Calculator Pro
on play store:
