[Tools] Home Network Settings
fmaster
I used to forget to turn off wifi and turn on data when i leave home so...
I started to made this app to my own use, but then i decided to share on Play Store.
2siTOC38z9SB6OXTALLRNOAInPvx3N8WBXMSiwpoxBb-ix0zalxJMPtOQvIp_SBSC54=w124
Google Play Store Link
REQUIRES ANDROID:
2.2 and up
All Features :
- Disable screen lock when you connect your home network.
- Turn off WiFi when you leave your home network.
- Turn on Data when you leave your home network.
- Turn off Data when you connect your home network.
- Turn on BlueTooth when you leave your home network.
- Turn off BlueTooth when you connect your home network.
- Disable Auto-Sync when you leave your home network.
- Enable Auto-Sync when you connect your home network.
- Change android profile when you leave your home network and when you connect to it. Profiles you may choose:
- Silent Mode;
- Normal Mode;
- Vibrate Mode;
LPXkjCi2SezPlGbzD9FuGnbGxNrckEeHu_zPBcfxa9dvaBMEvTa1Jzdvj-q5e_kKMqs
8OsTQkln0QkoOQeL72XdBCa1Cj4QAC4sHjUtDFQToSOdpVjGj6lrSPy-uIsItfpAwOw
myVIFcaf7j385MFUpt5hVHhSZ2GbTc4iUs0IuH8QrO4_lv9Cvy7GuYQbXYnEasuFzI0
Any suggestions to improve the app are welcome.
