Help top slide box not working
kyoman12
The top part of my kyocera, the slidy part dosent work and i have looked absolutely everywhere to how to fix it and nothing if anyone knows how to help me but remember this its not the freakin' unlock screen.
Could you possibly post a picture of what exactly you're referring to? What is the "slidy part"?
Dude its the thing where you get notifications and the hour but because of that i cant erase photos or send them
The notification pull down?
This part:
:confused:
Edit: the pic is from my one sv, but i have the hydro right next to me.
And it simply will not pull down? Or it's missing? Are you rooted? Did you remove any system apps?
