Top speaker distortion....
behrprofl
Member
I've had this phone for over a year now. I've always noticed this audio issue but never actually looked into it.
When we I'm listening music, podcast, movie, anything, the top speaker, above the camera, crackles when at the highest volume. My wife and son have the same phone and it does it on theirs as well. From what I can find online, almost everyone has experienced the same thing. Is there a fix? What is causing this issue?
Phone speakers can only handle so much before they are overdriven. Any brand, be it Android or iPhone.
Personally I play all of my music via Bluetooth to some decent Bluetooth speakers. The higher the wattage, the better it can handle higher volumes.
Good luck with your issue.
Avoid using maximum volume, that's just more than the speaker can handle. Use headphones or earbuds, also avoiding maximum sound levels. As @Dannydet referred to, it's just a common occurrence. Same problem can happen with stereo consoles, car sound systems, music concerts, etc. Your phones are no different.
when i want to listen to music from my phone(note 10+ 5G), i use either a bluetooth speaker or my samsung ear buds........you can get some small but pretty good speakers for relatively cheap. i never use the speakers on the phone. i find they are not very loud nor good to listen to that way.
