Torque Pro app
Well it depends if those data parameters are available in your specific vehicle. Oil temp in particular, not all engines have a sensor to measure it so it may be either an interpolated value or just non-existent. If a data item is present in the ECU but not part of the standard OBDII paramter set it may be necessary to add the parameter set for your vehicle as Mike mentioned. If that is not possible you may have to find the PID value for it to add it manually.
How can I update the vehicle manufacturer and vin number? I can only manually add the model in my profile and nothing else.
Those items are read from the vehicle, if they aren't showing up then they are not present or not supported and I don't think you can add them manually. Not all vehicles will send that info, especially older ones.
