Torrent Fu Problems
Hello All:
I am having problems getting Torrent Fu to work correctly on my Eris. I have done everything I can think of and need a new pair of ears to help me get past these problem.
I have done everything (which I think I did correctly( according to the setup page) and it is still not working. I have a port on my router open and even tested it and that is ok...
However my Eris is not able to see it nor send a torrent to the uTorrent app on the computer....
Anyone willing to help...please send me a PM or contact me on my IM names...I am always around and THANKS IN ADVANCE!!!
Scott
Wow turn the volume down lol.
1st, what torrent client are you using, utorrent?
2nd, are you able to connect to the web gui by typing in the URL in a web browser? Such as http://123.456.789.000/gui (123.456.789.000 should be replaced with your actual IP address).
Sorry, it is easier to see with my eyes...not meant to be considered as yelling...
Yes I am using uTorrent....
No, I am unable to get the "gui" up within a browser...I have been trying to figure that out since I am assuming if I can get that, then everything else will work...
Do you know your IP? If not, that could be a holdup.
Go here to find out.
Good luck. I use torrent fu with utorrent, and I think it's great.
Dan
Ok, I got the GUI to work, but when trying to select MANAGE I get an error...When trying to send a torrent to the computer I am getting an error...
It tells me the connection was refused...
What next?
Nope...I am unable to gain access to the GUI using the above example...
Ok. I went to the PORTFOWARD site and downloaded their CHECK IF MY PORT IS OPEN program and I did that...
I have opened the port I am using correctly...so we can eliminate that...
Figured out his problem for anyone that is interested. he had utorrent set to use port 1111 and in the webui settings had "alternate listening port" checked but was trying to use the same port which caused problems.
If you are using the same port for general utorrent traffic and the webui that option needs to be unchecked. Only check it if you want to use a different port for the webui.
Hi!
I have somewhat the same problem.
I am able connect on http://localhost:[my port]/gui, but not on http://[my external ip]:[port]/gui. And I have not used the same two ports as standard listening port and alternative listening ports.
I tried a sollution i read on the forum with setting the value of the ipfilter as false, but that didnt work either :(
So at first thought it may seem as my ports are not properly forwarded, but they are.
I know my ports are forwarded properly, i even checked with PF's checkertool. Anyhow, this problem results in an error when trying to press manage in torrent-fu.
It would be most pleasing if anyone were able to help. ;)
First Up, Hi all im a noob to android and custom ROMs but managed to root my Oranage Hero :D so well pleased but I now have an issue with torrent fu.
Ive had it working fine on the stock ROM so I know its not a settings issue but since moving to a custom ROM (Villaian V12) I struggle to connect to my home pc....I dont get the usual connection error it just times out :confused:
If I change the ports on both the device and utorrent and I can then connect? but once I've exited utorrent I cant then re connect unless I change the port again
Has anyone else experienced this ?
Any help would be much appreciated
Cheers
