Help torrent ........help
hi ppl..I m running htc explorer android 2.3 ...I have installed ttorrent and BitTorrent ..when I start torrent dwnld it goes fine but after an hour downld speed is 0 ..then i have to stop it and resume it again ..pls tell wat to do for continous downldng ..without stopping nd resuming many times..by d way torrent is healthy also no prblms wid network connection..
i
Because of what it's possible to download via torrent clients, a lot of network providers will block ports/limit the amount of data transfer when torrenting, that might be the cause of your issues?
A small word of warning however, torrents are notorious for malware distribution and pirated material. Please if you continue to use this app be VERY careful about the files you download. You could either be compromising your security or violating copyrights which is something we can not allow here.
thx for reply..my netwk is not blocking it ..nd I kno d other side of torrenting thx
