Root Total wipe of sequent
Bee1
I was formatting my sd because the new rom I flashed was reading only about 4gig when I had 16g total.Anyway ended up wiping out all data every where no phone,no system apps nothing.The only thing I can do is reboot into cwm recovery.I can sideload but don't know how...also pc can,t pickup sd.Any advice.I do have a backup on my desktop?
umm... how the hell did you manage that? lol. next time only press the format sd button, not format system
as far as fixing it, thank god you still have cwm. as far as the computer not picking up the sd, did you go into mounts and storage and hit the bottom option "mount usb storage"? because that should allow it to be read like a flash drive, other than that youll have to try to force something onto the sd through the computer directly using a card reader, and the problem might actually just be the sd card itself, if it was improperly formatted it can in fact crash the os itself, try booting up without the sd in there, and if you cant mount that card in cwm the way i described, try a different card
oh yea, and just for the sake of covering all the bases though im sure you understood why i said to connect it to your computer, toss a different rom on there or a backup, either way will work, then install/recover it
Can't find phone on my laptop when I mount usb on phone, just take me to another window saying...usb mass storage device leaving this menu unmounts your sd card from pc
Unmount
go back
I think I need the drivers again I can,t see my phone.I can get to sideload all the way to usb mount then unmounts then go back?
You are f**king good and that real talk.It worked
Did I forget to say THANK YOU!....just so happy to have my phone back..
Thank you super.
